SdrPlay RSP2 /Dsdplus problem
- nordhavn
I'm having problems using dsdplus with an sdrplay rsp2.
Finding it a tad frustrating to say the least lol .Any tips or help would be much appreciated .
- thelad
Re: SdrPlay RSP2 /Dsdplus problem
Whats the issue?
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- thedeerhunter270
RX EX Control
FM DEEM (button): Clicking the "DEEM" button to activate the de-emphasis function. Set to off.
- nordhavn
- nordhavn
Still not working
- thedeerhunter270
There are 3 things you need to have set right.
1. VAC needs to be set as default input device in Windows.
2. In SDRUno VAC needs to be set as default output device.
3. In SDRUno de-emphasis needs to be set to off.
Hopefully it should work then.
- nordhavn
Still no luck . from what I gather I won't hear anything until it recognises a digital mode (no white noise etc) .Now I'm thinking I'm on the wrong frequency .Any suggestion on where to look ? Sorry complete newbie to digital stuff .
- radiogaga
- Call Sign: 26TM399
Here is a start where you know there will be some DMR traffic and you will know colour codes and slots:
https://www.ukrepeater.net/dmr.htm
30TM399 Northern Costa Blanca
- nordhavn
Ill have to borrow a Motorola dp1400 from work to see if it works .
- radiogaga
Do you not have one of those repeaters nearby?
- nordhavn
No sadly ... I'm a on the west coast /mid Wales .
- radiogaga
Ah, I misread your location of s/e as South East
Do you have an analogue scanner?
- thedeerhunter270
Try this page to help with DMR identification. Have a tune around and see if you hear something similar - then try it with DSD.
https://www.sigidwiki.com/wiki/Digital_ ... adio_(DMR)
- radiogaga
Start with business licence frequencies. I’m in the middle of nowhere and still hear those who have moved across. That was going to be my suggestion as you can set scan limits with an analogue scanner.
- nordhavn
