SdrPlay RSP2 /Dsdplus problem
nordhavn
Post by nordhavn » 24 Apr 2018, 19:45
I'm having problems using dsdplus with an sdrplay rsp2.
Finding it a tad frustrating to say the least lol .Any tips or help would be much appreciated .
thelad
Re: SdrPlay RSP2 /Dsdplus problem
Post by thelad » 24 Apr 2018, 21:17
Whats the issue?
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
thedeerhunter270
Post by thedeerhunter270 » 25 Apr 2018, 09:16
RX EX Control
FM DEEM (button): Clicking the "DEEM" button to activate the de-emphasis function. Set to off.
nordhavn
Post by nordhavn » 26 Apr 2018, 20:28
thelad wrote:
24 Apr 2018, 21:17
Whats the issue?
Can't seem to listen to dmr ... I've also installed virtual cable .
nordhavn
Post by nordhavn » 30 Apr 2018, 17:17
Still not working 😞
thedeerhunter270
Post by thedeerhunter270 » 01 May 2018, 06:41
There are 3 things you need to have set right.
1. VAC needs to be set as default input device in Windows.
2. In SDRUno VAC needs to be set as default output device.
3. In SDRUno de-emphasis needs to be set to off.
Hopefully it should work then.
nordhavn
Post by nordhavn » 05 May 2018, 16:41
Still no luck . from what I gather I won't hear anything until it recognises a digital mode (no white noise etc) .Now I'm thinking I'm on the wrong frequency .Any suggestion on where to look ? Sorry complete newbie to digital stuff .
radiogaga
Call Sign: 26TM399
Post by radiogaga » 05 May 2018, 16:55
Here is a start where you know there will be some DMR traffic and you will know colour codes and slots:
https://www.ukrepeater.net/dmr.htm
30TM399 Northern Costa Blanca
nordhavn
Post by nordhavn » 05 May 2018, 17:26
Ill have to borrow a Motorola dp1400 from work to see if it works .
radiogaga
Call Sign: 26TM399
Post by radiogaga » 05 May 2018, 17:29
Do you not have one of those repeaters nearby?
nordhavn
Post by nordhavn » 05 May 2018, 21:01
No sadly ... I'm a on the west coast /mid Wales .
radiogaga
Call Sign: 26TM399
Post by radiogaga » 06 May 2018, 06:13
Ah, I misread your location of s/e as South East :D
Do you have an analogue scanner?
thedeerhunter270
Post by thedeerhunter270 » 06 May 2018, 06:43
nordhavn wrote:
05 May 2018, 16:41
Try this page to help with DMR identification. Have a tune around and see if you hear something similar - then try it with DSD.
https://www.sigidwiki.com/wiki/Digital_ ... adio_(DMR)
radiogaga
Call Sign: 26TM399
Post by radiogaga » 06 May 2018, 08:25
Start with business licence frequencies. I’m in the middle of nowhere and still hear those who have moved across. That was going to be my suggestion as you can set scan limits with an analogue scanner.
nordhavn
Post by nordhavn » 06 May 2018, 12:55
radiogaga wrote:
06 May 2018, 06:13
I do apologize .. I've updated my profile now .
