Major M588 ptbm059 am/fm frequence issue.
- Call Sign: 56la422
I donno what is wrong with Major M588 frequencies,WHY there is so big difference between modulations?.
Powersupply 13.8v
ch20 tx freq
FM 27.204663MHz
AM 27.205043MHz
X1 10.240 crystal freq
10.240000MHz
Compare to Ham multimode 2 ptbm059
ch20 tx freq
FM 27.205518MHz
AM 27.205617MHz
10.240002MHz
http://ham-international.nuxit.net/PTBM ... glages.htm
Anyone have better alignment brochure?
Edit.
There seems to be a bit different parts on the PTOS006AOX board.
Major
R26 100ohm
R23 18k ohm
R27 2.2k ohm
Multimode 2
R26 680ohm
R23 8,2k ohm
R27 1,2k ohm
Powersupply 13.8v
ch20 tx freq
FM 27.204663MHz
AM 27.205043MHz
10.240000MHz
ch20 tx freq
FM 27.205518MHz
AM 27.205617MHz
10.240002MHz
Edit.
Major
R26 100ohm
R23 18k ohm
R27 2.2k ohm
Multimode 2
R26 680ohm
R23 8,2k ohm
R27 1,2k ohm
Paljon pilalle tinailtuja koneita.
Re: Major M588 ptbm059 am/fm frequence issue.
Is anyone having same issue?.
I own 5pcs M588 and all same problem.
Is there some component or voltage diference somewhere why MM2 is a bit better am/fm stability.
- Otter
- Call Sign: 26TM439
Is there any difference in voltage on the emitter of Q44 when you change modes?
Not much.
I looked from schema it should be 9,4v
13.8v psu
Major
RX
FM 9.26V
AM 9.27V
USB 9.25V
LSB 9.25V
TX non modulated
FM 9.17V
AM 9.18V
USB 9.20V
LSB 9.20V
MM2
RX
FM 9.60V
AM 9.61V
USB 9.59V
LSB 9.59V
TX non modulated
FM 9.49V
AM 9.50V
USB 9.55V
LSB 9.55V
13.8v psu
Major
RX
FM 9.26V
AM 9.27V
USB 9.25V
LSB 9.25V
TX non modulated
FM 9.17V
AM 9.18V
USB 9.20V
LSB 9.20V
MM2
RX
FM 9.60V
AM 9.61V
USB 9.59V
LSB 9.59V
TX non modulated
FM 9.49V
AM 9.50V
USB 9.55V
LSB 9.55V
I measured a bit more.
TX on IC3 pin 1
Major
FM 10.695002MHz
AM 10.695002MHz
MM2
FM 10.695015MHz
AM 10.695015MHz
So that is fine or maybe a bit high to Multimode.
I think i have to measure voltages if there is something ...
TX on IC3 pin 1
Major
FM 10.695002MHz
AM 10.695002MHz
MM2
FM 10.695015MHz
AM 10.695015MHz
- Ashtec
- Call Sign: M6LTD
If i was you i would see how the radio is frequency modulated...
ie....By the xtals or is it by a conversion to the vco...
I say this as it looks when in FM mode the frequency is dropping or being dragged down.
- 14CS06
Hello Ashtec
Happy to see you here
Claude
Claude
Only 22ohm bias mod on Major.
I donno what mod is made to MM2 but channel guard and maybe some kinda microphone preamp.
I have to look osciloscope and spectrum analyzer how both act with TX.
Another 588 arrived and this time Black spirit moded.
I have to check this too.
Problem maybe solved atm.
I have to make aligment again and after that i can say if it helped.
All M588 same issue and manufactured wrong because 9v voltage coming from FM/AM/SSB selector AM without diode and FM thru diode so it drop about 0.5v.
So i added diode both and frequence is really stable . 27.205 FM -> 27.205387 . AM -> 27.205400.
Same issue this one too.
- Ashtec
- Call Sign: M6LTD
Interesting to know.
- cb4ever104
- Ashtec
- Call Sign: M6LTD
Glad to be back..
