Major M588 ptbm059 am/fm frequence issue.
pienari
Call Sign: 56la422
Post by pienari » 01 Jun 2017, 12:18
I donno what is wrong with Major M588 frequencies,WHY there is so big difference between modulations?.
Powersupply 13.8v
ch20 tx freq
FM 27.204663MHz
AM 27.205043MHz
X1 10.240 crystal freq
10.240000MHz
Compare to Ham multimode 2 ptbm059
ch20 tx freq
FM 27.205518MHz
AM 27.205617MHz
10.240002MHz
http://ham-international.nuxit.net/PTBM ... glages.htm
Anyone have better alignment brochure?
Edit.
There seems to be a bit different parts on the PTOS006AOX board.
Major
R26 100ohm
R23 18k ohm
R27 2.2k ohm
Multimode 2
R26 680ohm
R23 8,2k ohm
R27 1,2k ohm
Paljon pilalle tinailtuja koneita. ;)
Mobile. Harrier CB X, Megawatt 4000,Zetagi B300p.
Home. Colt Excalibur SSB , 2el Quad, Eurocb EA-150.
pienari
Call Sign: 56la422
Re: Major M588 ptbm059 am/fm frequence issue.
Post by pienari » 05 Jun 2017, 13:05
Is anyone having same issue?.
I own 5pcs M588 and all same problem.
Is there some component or voltage diference somewhere why MM2 is a bit better am/fm stability.
Otter
Call Sign: 26TM439
Post by Otter » 06 Jun 2017, 13:54
Is there any difference in voltage on the emitter of Q44 when you change modes?
pienari
Call Sign: 56la422
Post by pienari » 06 Jun 2017, 14:52
Not much.
I looked from schema it should be 9,4v
13.8v psu
Major
RX
FM 9.26V
AM 9.27V
USB 9.25V
LSB 9.25V
TX non modulated
FM 9.17V
AM 9.18V
USB 9.20V
LSB 9.20V
MM2
RX
FM 9.60V
AM 9.61V
USB 9.59V
LSB 9.59V
TX non modulated
FM 9.49V
AM 9.50V
USB 9.55V
LSB 9.55V
pienari
Call Sign: 56la422
Post by pienari » 06 Jun 2017, 16:37
I measured a bit more.
TX on IC3 pin 1
Major
FM 10.695002MHz
AM 10.695002MHz
MM2
FM 10.695015MHz
AM 10.695015MHz
So that is fine or maybe a bit high to Multimode.
I think i have to measure voltages if there is something ...
Ashtec
Call Sign: M6LTD
Post by Ashtec » 11 Jun 2017, 17:08
If i was you i would see how the radio is frequency modulated...
ie....By the xtals or is it by a conversion to the vco...
I say this as it looks when in FM mode the frequency is dropping or being dragged down.
14CS06
Post by 14CS06 » 11 Jun 2017, 19:11
Hello Ashtec
Happy to see you here
Claude
pienari
Call Sign: 56la422
Post by pienari » 12 Jun 2017, 19:18
Only 22ohm bias mod on Major.
I donno what mod is made to MM2 but channel guard and maybe some kinda microphone preamp.
I have to look osciloscope and spectrum analyzer how both act with TX.
pienari
Call Sign: 56la422
Post by pienari » 09 Sep 2017, 07:47
Another 588 arrived and this time Black spirit moded.
I have to check this too.
pienari
Call Sign: 56la422
Post by pienari » 12 Nov 2017, 14:12
Problem maybe solved atm.
I have to make aligment again and after that i can say if it helped.
All M588 same issue and manufactured wrong because 9v voltage coming from FM/AM/SSB selector AM without diode and FM thru diode so it drop about 0.5v.
So i added diode both and frequence is really stable . 27.205 FM -> 27.205387 . AM -> 27.205400.
pienari
Call Sign: 56la422
Post by pienari » 18 Nov 2017, 17:22
pienari wrote:
09 Sep 2017, 07:47
Same issue this one too.
Ashtec
Call Sign: M6LTD
Post by Ashtec » 01 Mar 2018, 23:35
Interesting to know.
cb4ever104
Post by cb4ever104 » 02 Mar 2018, 09:21
Ashtec wrote:
01 Mar 2018, 23:35
Nice to see you back Paul :)
Ashtec
Call Sign: M6LTD
Post by Ashtec » 03 Mar 2018, 14:49
cb4ever104 wrote:
02 Mar 2018, 09:21
Ashtec wrote:
01 Mar 2018, 23:35
Glad to be back..
