Hello from Yorkshire
A place for new members to say hello and to introduce yourself.
If you're not sure where to post, try here!
AndyDCD
Call Sign: M0DCD
Post by AndyDCD »
Evening folk, new to here.
Hamming it mostly on 2m, take part in UKAC when the weather allows, do a bit of SOTA. Some HF, I get my arm twisted to do HF contesting occasionally.
A bit of PMR446 DXing, and do the odd restoration of ancient kit just to keep my skills honed.
Some 11m/CB gear ancient and modern, FT817, FT450D, FT950, FT2900 and a collection of handhelds.
Current work gets me all over the UK mainland, occasionally with overnight stays, where I can find that the portable kit has "accidentally" found its way into the works vehicle.
Allan666
Call Sign: G0CRB
Re: Hello from Yorkshire
Post by Allan666 »
Hi Andy and welcome.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix »
Welcome to the forum. Occasionally do the UKAC contests myself, more to just give points away than play the game that is, but who knows, might get you in the log one day.
Welcome to TM1 :-D
