Yaesu 450d no tx or rx from 24-30mhz
Ok so i just got me a yaesu 450d but here is the problem it won't rx or tx from 24-30mhz. I've tried by passing the atu and still the same thing. I've just had a look for dry joints and all seems ok. When i tx it showing on my psu that it's drawing power but the same type of power that it would draw if you had a high swr. I'm not going to send it for repair so please don't recommend shops if i can't get it working it will just stay gathering dust. It has some sentimental value. Any help would be great.
- Buick Mackane
Re: Yaesu 450d no tx or rx from 24-30mhz
I'm by no means an expert but i would suspect one of the bandpass filter relay's is faulty
- Buick Mackane
It's possible if the radio has been modified to TX on 11m that the bandpass filters have been damaged
The person was using it on 11 meters at the time it went bad. I'll have to dig out a rf probe and check it out when i have the time thanks.Buick Mackane wrote: ↑29 Mar 2023, 16:41 It's possible if the radio has been modified to TX on 11m that the bandpass filters have been damaged
Check VCO voltage(s) first. Use plastic or ceramic tool to adjust. Do not break ferrite cores.
Anyone have any other clues ?
BPF7 is 21.5-33MHz. Is radio working between 21.5 and 24?
Also try to bypass tuner.
It works on 21.5 - 24mhz. I've also tried bypassing the ATU and it's still the same.
Sorry i made i mistake it don't work from 21.500mhz - 33mhz.
- Buick Mackane
Take it you've tried a factory reset ?
Yeah tried that didn't do nothing.
So BPF7 or it's logic is suspected. Check if it get switching signal (J2003), than check switching diodes of BPF7, finally bypass it with some capacitor.LondonCbRadio wrote: ↑03 May 2023, 11:17 Sorry i made i mistake it don't work from 21.500mhz - 33mhz.
Sorry bypass what ?
- Buick Mackane
I Presume he means the band pass filter
