Perspex on front of radio scratched
I can't see the signal meter on a radio i got because it looks like someone has sanded part of it,is there anyway to make it clear again ?
Re: Perspex on front of radio scratched
It can be polished.
I was told by someone to get 1200grit sandpaper but it's made it worst
Sandpaper for deeper scratches.
For finishing you should use polishing paste/fluid and soft cloth.
Use finer and finer grades of wet & dry paper (up to 2/3000 grit) and then polish the hell out of it, or do the finer and finer sanding bit then use a warm vapour canister to melt the surface clear. Watch this for example, but there are plenty of similar videos out there:
https://youtube.com/shorts/cmWxoJLHvF8?feature=share
Kits are available from £14 upwards, but do it outside and hold your breath as the vapours are somewhat toxic!
Give 'Marty's Matchbox Makeovers' a watch on youtube. He shows various methods of repairing and polishing broken or scratched windows on toys. Not tried it myself though.
One person in ten understands binary, the other one doesn't.
1500/2000 grit more like with plenty of water then finish off with a finishing car polish
DELETE MY ACCOUNT
- DX-Digger
- Call Sign: TM205
I have seen it done with a small gas torch but you have to be quick so it doesnt distort or bubble up.
But It would be a last resort only if the polishing didnt work. might be simpler to try and find one on the internet.
Post a picture it may be the same as other radios.
- Tin soldier
Depends how bad/deep the scratches are.
But you should get away with t-cut and a bit of elbow/knuckle grease
I've used t-cut on plastic car headlights and plastic wristwatch crystals . They come up like new.
Don't use any thinners FFS
And I personally wouldn't be putting any heat near it.
And as edd200sx said.
- 108AW027
- Call Sign: 108TM119
I have used this stuff before on plastic car headlights,,done an ok job
https://www.ebay.co.uk/itm/313441818116
108 FB 027--108 TM 119
- 14CS06
- Otter
- Call Sign: 26TM439
I've used displex display polish a few times <link>.
The depth of the scratches are the key as to how to remove them. The deeper they are then more likely it is that sandpaper is the best option. But fine surface scratches can be polished out with toothpaste or moistened baking powder.
- Call Sign: G4RMT
Watch the videos on table making and epoxy modelling. The paper goes 1000, 2000 and higher then the various creams, and the thing is cloudy, less cloudy and then perfect it seems.
