KPO NM 532 MICROPHONE
- Nitehawk
Hi all, can you guys tell how to wire a kpo nm 532 mic for a Alan 9001 radio, what colour wires go in what number pin, not technically minded this way. Thankyou in anticipation.
- Buick Mackane
Re: KPO NM 532 MICROPHONE
I Had a quick look online and this is what i found, Blue is RX White is TX And red is audio,Braid is common. So using the diagram below Red audio goes to pin one on the radio. Braid goes to pin two, White goes to pin three, Looks like blue isn't used, This is only some info i found online so make no guarantees and you wire it up at your own risk
- Nitehawk
Thankyou for the info, all up and working fine.
- Buick Mackane
No hassle glad you got it working
