Hi can someone tell me is this the right setup...
President harry 2 - zetagi B-132 - swr/pwr meter -antenna
Its been a long time since i was on the radio and ive dug out a setup to get going.
My president harry is doing exactly 4 watts through a 1:1 match on my 200watt dummy load I then switch the B-132 on and on the swr/pwr meter its showing 50 watts but on the b-132 meter its showing almost 120 watts?
Ive seen a youtube vid of a guy putting 5watts from his radio through his B-132 and he's getting 120 watts on his swr/pwr meter and the B-132?
Can someone please confirm my setup is correct and is 50 watts about right for 4 watts in ? Thanks
president harry 2 - zetagi B-132
- Call Sign: 26TM2010
Re: president harry 2 - zetagi B-132
4W in, 50-60W out. External meter show the truth. More or less
I wouldn't use it in other mode than FM cause it's C-class splatter box.
Hi realised theres a 4 watts innput switch on the back so i am now 70 watts output.
I don't run linear amps on AM nor do i go stupid on FM ......Thanks for the advice
