Been asked to look at a 6900n that has no life whatsoever. It doesn't power up, they've changed the fuse, power cable, different power supplies etc. It all stays blank, no lights and no display. I was wondering if they have a safety feature that prevents the radio from powering up if they have a serious fault to prevent any further damage? Or a reset procedure? Any help would be appreciated.
Thanks.
Natalie.
Dead 6900n
Re: Dead 6900n
Take DMM and check where voltage disappear.
- Otter
- Call Sign: 26TM439
Re: Dead 6900n
I'd chack the on/off switch. Also check for any burnt tracks.
There's no safety feature that I have ever heard of.
To reset hold down the func and scan buttons while powering-on the radio. Release the buttons when you see RES on the screen.
- Buick Mackane
Re: Dead 6900n
My first port of call would be the voltage regulator
- yaggiboom
Re: Dead 6900n
Thanks for thee replies, looks like its going to be a bit of detective work, basic fault finding. If volts are going in, then they have to be somewhere. I haven't looked at it yet so what the state of it is I don't know. If its all dead then its better than just one circuit or the intermittent .........now you see me, now you don't fault, that for sure.
- astradyne
Re: Dead 6900n
Clip the reverse polarity diode and see if it bursts into life.
- Otter
Re: Dead 6900n
If it's not blowing fuses with the power switch turned off *DON'T* do this ^^^^^
