Birds on antenna radials
Hi All
Anyone got any tips to stop birds landing (and crapping) on the radials of my Sirio 827 .
Thx in advance
Thx in advance
Re: Birds on antenna radials
NLAW, Javelin, 12-bore, AK-47, M60....the choice is yours, depending on how strong your arms are
What about some thick axle grease stuff. Gloopy enough not to wash off easily or be frazzled by the sun too quickly. I'm not sure if copper grease would block anything signal-wise, but I wouldn't have thought so???
As long it is not condor or turkey there is nothing to be worry about.
- Auldgeek
- Call Sign: GM0BRJ
I've long since given up trying to stop birds from sitting on my antennas. My main mast holds my 6m through to 23cms yagis, so there's literally dozens of elements for them to roost on.
I actually don't mind the small birds, it's our wood pigeons from "Bomber Command" that crap all over my garden.
I clean everything up on the mast when it's down for annual checks, but that's all I do.
Auldgeek - Drew
Seagulls i have to put up with.
They crap all over and regularly fly into my antennas.
Little birds are welcome any time as said they do no harm.
Picture 25 or so starlings sat on my 7 band cobweb aerial it sure does wobble a bit lol.
Yeah. The sparrows are having a field day on my Sirio. I think I might try some grease on the radials to see if it makes any difference.
Birds used to sit on our old neighbour's TV aerial above our drive, which the previous owner had allowed them to fit it up there on our house as we were on the end. A guy round the corner had bloody homing pigeons that'd adorn the thing. They'd crap that much, that my ex-wife's Metro looked like it had white polka-dot paintwork. I ended up moving the aerial and strapping it to their satellite dish mast as the sh** would eat into the car's paint as it hadn't long had a respray when we bought it.
- Transwarp
- Call Sign: Viper
Try a realistic looking bird of pray fixed near antennas. Failing that rig up a plant watering device with a sensor that sprays a stream at the area when birds trigger it.
Yeah..a helium-filled Kestrel balloon attached to the top
Tried that . Think the birds have crapped on that as well They're pretty smart .
4 words . "Grease is the word"
Put some general purpose grease on the radials and they no longer land on them. Problem sorted
Nice one.
The only other thing I could've suggested was a mesh/net hanging from about 4ft up over the ends of the radials like an upside-down Sigma basket/crow's nest.
The top would have to be gripped by some duct tape and a hose-clip over the top.
The downside could be though that the bird's legs night get tangled and you might have the odd dead pigeon hanging from the aerial!
Fingers crossed that's the end of the issue. Just re-apply elit every now and again as the heat will eventually dry the grease up.
An old ham trick is to mount some type of bird of prey life size model on your set up etc'' seen a few Barn Owls weatherd and no 'birds around'
Tried that . Bought 2 "owls" on Amazon , but the birds took about 20 minutes to figure out that they weren't real . The sit right next to it now
- gmham
- Call Sign: 108TM154
Best method I have read but never personally tried is to wrap small plastic cable ties in a criss cross pattern spaced along the length of the radials, works in the same principle as the spikes you see on the tops of buildings etc .
Can also confirm the plastic bird of prey idea works….for the first hour or so !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
