Help icon ic 706mk2g no audio out
Hi all hope somebody may be able to help me out I have a ICOM 706mk2g with no audio output on all bands it transmits fine it receives fine as well can anybody point me in the right direction to resolve this issue any help any pictures anything would help thank you
Re: Help icon ic 706mk2g no audio out
First I would check micgain.
Than another microphone.
Than measure voltage between pins 7-1 and 5-6 in microphone socket.
Than apply audio to ACC1 pins 2-11
Come back with results.
From the original mic opened up
Pin 5 and 6 .036v
Pin 1 not connected
Acc1 pin2 and 11 .040v
Acc1 pin1 and 2 .002v
Pin 5 and 6 .036v
Pin 1 not connected
Another microphone?
Now tested another two originals mic with no modulation ?
What if you apply audio to ACC socket? Can be from PC soundcard, but PTT also must be from ACC
Add a mic to ACC1 pin 2 and pin 11 when I press the PTT to talk I can now hear voice what is the next step?
Voice on all band
Did you check micgain setting in menu? It affect only mic socket.
Next step is to trace signal from microphone socket backwards.
Mic gain is set to 5 as default it doesn't make any difference whether I turn up or down
Measure voltages on Q961
If OK apply some audio on base of Q961 and see if there is any output on TX
Q961 top was 6.29v left was 4.52v and the right 3.86v
So apply some audio on it's base
