discone or x30 sdr scanner RX
Ur5by9
Post by Ur5by9 »
I have been having a play around with sdr on the cheep
Just a USB dongle using SDR Sharp with a small desktop antenna
I was considering a discone antenna for a bit more sdr fun but I do have a diamond x30 tucked away that could be used
any advantages of using a dedicated discone over a vhf white stick?
OR
some thin wire draped around the loft space 30 / 40 meters is also quite possible
What's your thoughts?
Call Sign: Lemmy
Re: discone or x30 sdr scanner RX
Post by ch25 »
x30 have bandwidth limited to amateur bands. if you want to listen outside them, you need different antenna.
Ur5by9
Post by Ur5by9 »
Hi ch25 what would you go with ?
Call Sign: Lemmy
Post by ch25 »
