FT-991A Fan mod
Alan Pilot
FT-991A Fan mod
Post by Alan Pilot »
Anybody done this mod recommend a replacement fan. (60x25)..
The one i see mentioned a Sun?????? is not available well i can't find one to buy in the uk.
Any help.
Thanks.
Auldgeek
Call Sign: GM0BRJ
Re: FT-991A Fan mod
Post by Auldgeek »
I no longer own my 991A, but a quick Google and brief read of some QRZ forum discussions on this, I found the link to a UK supplier of the Sunon fan outlined in the modification.
https://uk.rs-online.com/web/p/axial-fans/1356902
Link to discussion on QRZ.
https://forums.qrz.com/index.php?thread ... od.665198/
The Sunon fan is mentioned at the bottom of page 1. However, there's no reason why you can't fit another make. Key is to ensure the airflow is good enough, the fan has a lower noise level and it doesn't draw more current than the factory fitted Panasonic.
Good luck...
Auldgeek - Drew
Alan Pilot
Re: FT-991A Fan mod
Thanks for that one.
I did find it there but on back order no idea how long it would take to get one from them.
Auldgeek
Call Sign: GM0BRJ
Re: FT-991A Fan mod
Post by Auldgeek »
Alan Pilot wrote: 04 Apr 2022, 15:30 Thanks for that one.
RS are quoting 12th April dispatch.
Auldgeek - Drew
Alan Pilot
Re: FT-991A Fan mod
Thanks again.
Will get on to them in the morning.
Auldgeek
Call Sign: GM0BRJ
Re: FT-991A Fan mod
Post by Auldgeek »
Alan Pilot wrote: 04 Apr 2022, 19:52 Thanks again.
You're welcome :thumbup:
Let me know how you get on. Fan noise can drive you potty.
I had to do the same to a power supply that had a built-in jet turbine for a cooling fan!
Auldgeek - Drew
Alan Pilot
Re: FT-991A Fan mod
Auldgeek
I found this one last night and looks to be about the same as the recommended Sunon i think.
Only just noticed it doesn't show the link i posted but this is the one i found on amazon.
Sunon EE60251S11000U999
Alan Pilot
Re: FT-991A Fan mod
bay link to the same fan.
https://www.ebay.com/itm/233391704392
Auldgeek
Call Sign: GM0BRJ
Re: FT-991A Fan mod
Post by Auldgeek »
Alan Pilot wrote: 05 Apr 2022, 08:44 Auldgeek
Think this the fan you're looking at..
https://www.amazon.co.uk/dp/B07ZBQXD83/ ... ZCJWNDWXGW
At 27dba, it's mightily quiet. Slide bearing too, so it should be reliable.
Auldgeek - Drew
Alan Pilot
Re: FT-991A Fan mod
That is the one yes.
When i put the link in it didn't show in the post.
I bought one so we will see and if it is ok might just buy another as a spare.
Funny thing is they where £7 when i bought it soon put the price up.
Alan Pilot
Re: FT-991A Fan mod
Got the fan and only tested it on 12v and boy does it move some air but that is flat out.
Going to give it a go but in a day or so got man flu at the moment lol.
Pluskat
Call Sign: 16op234
Re: FT-991A Fan mod
Post by Pluskat »
I have changed all the fans in my radio's and power supply's.
I only use Noise blocker fans....take a look at these fans.
Alan Pilot
Re: FT-991A Fan mod
I had a look at the noise blocker fan but the specs where way out.
Wattage is 2.8 but radio fan is 1.5?.
CFM is too low on them as well.
Thanks anyway might use them in a power supply sometime.
