Magpie Autoscan 5000
NightProwler
Call Sign: 163TM186
Post by NightProwler »
Hey all. Just dug out my Magpie Autoscan. The bulb has gone in the meter which is no problem but the channel display is really dim and hard to see. Anyone got any ideas?
Cheers...Rich
The Collector
Re: Magpie Autoscan 5000
Post by The Collector »
As you well know, I know naff all abput radio innards, so no laughing at my attempts to help :)
As the channel indicators are basically some sort of fluorescent tubing, is there some sort of electronic ballast/starter that provides a boost of voltage to the display unit that you know of, like on the tubes we get in domestic properties etc?
NightProwler
Call Sign: 163TM186
I know what you mean. When I cover the 'magic eye' thingy for the dimmer it makes no difference. It was brighter when the signal meter bulb worked so could they be related some how? I dunno :?
The Collector
You should be able to find a schematic off the internet (not that it would help me at all!), but if you can't find one, I might have an A4 copy plus my original manual of the instructions, if that's got them in.
Does banging the lid hard make any difference? :crazy:
Otter
Call Sign: 26TM439
Post by Otter »
Is the light sensor clean? it seems to be a phototranssitor called a 1N5777, but I can't find any info on it. That drives a BC237, and that could be faulty / have a dry joint.
Edd200sx wrote: Edd200sx may have some words of wisdom on this.
Edd200sx
Post by Edd200sx »
Otter wrote: 03 Mar 2022, 21:21 Is the light sensor clean? it seems to be a phototranssitor called a 1N5777, but I can't find any info on it. That drives a BC237, and that could be faulty / have a dry joint.
I’d run through the whole radio for dry joints tbf
The front panel especially! The up down buttons are also
Worth stripping and cleaning as they play up
Can’t help with the dimmer sensor as I’ve only got one spare
For my own radio
DELETE MY ACCOUNT
The Collector
Perhaps replace the meter bulb first. You never know, that might then release power to other components???
I'm probably talking out of my ass ;)
Reason: Cleaned up a slighty naughty word
Buick Mackane
Moderator
Moderator
Post by Buick Mackane »
The Collector wrote: 03 Mar 2022, 23:30 Perhaps replace the meter bulb first. You never know, that might then release power to other components???
Thats what i would do first, Change the meter bulb that is, Not talk out my ass :lol:
NightProwler
Call Sign: 163TM186
I got some bulbs somewhere so I will change that first. I dont really want to mess with it too much because the radio is in almost mint untouched condition. I have tried giving it a gentle 'slap' but nothing happened .
Edd200sx
Post by Edd200sx »
Unfortunately you will have to strip the front panel to do
That dimmer part if you can find one. Or reflow it and
See if it works
DELETE MY ACCOUNT
cb4ever104
Post by cb4ever104 »
Edd200sx wrote: 04 Mar 2022, 15:04 Unfortunately you will have to strip the front panel
Don't you just hate those types of radios.. The Lincoln is the same. Strip the whole front down to sort a bent pin on one of the push buttons..
Edd200sx
Post by Edd200sx »
cb4ever104 wrote: 04 Mar 2022, 21:06
The pie is terrible, desolder the mic socket.
The flimsy plastic connectors to the main board are impossible to desolder. So that’s a bit of a job to rewire
DELETE MY ACCOUNT
The Collector
I've had a few radios like that, disassemble the whole front panel to access the locking ring on the mic' socket or like that one, desolder all the mic' pins to get the front off. Half an hour's work just to replace the bloomin' meter bulb!
Why didn't manufacturers think about these things, or were they just trying to get you to send it back to them for costly repairs?!
Edd200sx
Post by Edd200sx »
The Collector wrote: 05 Mar 2022, 13:28 I've had a few radios like that, disassemble the whole front panel to access the locking ring on the mic' socket or like that one, desolder all the mic' pins to get the front off. Half an hour's work just to replace the bloomin' meter bulb!
Actually think maybe you can do the meter without stripping it.
It’s the light sensor is a different case
DELETE MY ACCOUNT
Otter
Call Sign: 26TM439
Post by Otter »
Uniden improved over time. Originally (1977-ish) stuff was mounted directly to the fascia, but later started mounting to a front chassis. Then the Lincoln wasn't so good again.
