Have a look at the circuit board in your radio. You should see the number 481902C. Lots of these Maxon built AM radios were based around just a couple of PCBs.
Ticking an old box (Commtron box~)
- Otter
- Call Sign: 26TM439
Re: Ticking an old box (Commtron box~)
Fantastic Claude
thanks
Exactly the same and resistor present too - so I am right mine has broken off the signal meter black cable terminal
Great info there Cheers
thanks
See attached photo
with CB turned on I get 13,8v on the the middle leg of this transistor - nothing on the outer legs
is this normal?
is this normal?
- Mitch
- Call Sign: M1TCH
Yes, perfectly normal, one side is earth, middle is power and output, other is signal in.un-realistic wrote: ↑14 Feb 2022, 10:36 See attached photo
is this normal?
The perfect face for radio.
Great thanks
Just looking at trying to solve the low TX power - well I should say low TX power according to the units signal meter just over 1W
Hoping with the use of a SWR and watt meter I can confirm this output, am I to connect my dummy load to the SWR meter and then SWR to CB?
- Call Sign: 26TM773
You don't need a swr meter if you have a dummy load.
Just put the dummy load in the ant socket on the power meter and radio to the other one.
But how then would I prove the true TX power output i.e. that the meters own signal indicator is correctly displaying power and doesn't need calibrated.
If in fact I am only producing 1+ W TX - where do I start diagnosing the cause?
You need an accurate power meter.
Don't believe the built in signal meter.
- Buick Mackane
Dummy load & a decent quality power meter, The radio might just need the TX Stages aligned, But keep in mind that not every 27/81 radio is capable of producing the full 4 watt legal limit.
- Otter
I'd look at the output transistor and see whether it's the correct one for the radio. If it looks like it may have been replaced, try to work out whether the transistor is a genuine one.
