How deep would you recommend burying/planting a 2" pole for a babyloop ? It's only 2m above ground but the loop weights 16kg . The ground where it will be situated is fairly soft .
Regards
Babyloop mast ?
Re: Babyloop mast ?
Depends on wind speed in you area.
- nordhavn
Re: Babyloop mast ?
1m deep, concrete filled hole would be more than enough.
