Seems cheap enough eh ?! Seem to remember parrot repeaters being sold before but this would probably be a better idea ?
Anyone uses similiar ?
https://www.ebay.co.uk/itm/353756839208
Cheap repeater ?
- gmham
- Call Sign: 108TM154
Cheap repeater ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Metradio
- Call Sign: G7HID
Re: Cheap repeater ?
The cheap cross band repeaters have been around a while and once the VOX levels are set up they work well. It is advised that the 2 radio antenna are spaced out from each other as far as possible, >15ft..
I think these work on a first come first served basis, others can have a VHF or UHF priority..
They seem to work cross mode with no problems..
Mike
Mike
- gmham
Thanks mike appreciate the info yes must admitt did cross my mind how the two radios would work sitting right next to each other buy yes if making a permanent or semi permanent set up you would obv try use a decent external antenna as opposed to just using the two radios with there set top aerials . Just need to find a local hill to site it !!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Metradio
- Call Sign: G7HID
An even better solution with DTMF remote control so you can activate and shut down etc..
https://www.ebay.co.uk/itm/274065554882
My testing was done on a high rise building with radio antenna separated vertically .
The most important thing is the quality of the radio receivers quality.
Mike
Mike
If you have a raspberry pi and a USB audio card you can make use of my parrot repeater script, the repeater boxes above won't work on 446 as there is insufficent bandwidth between the channels to set up a duplex repeater. That is unless the apparatus can operate in simplex mode (Parrot).
https://github.com/decoderstar/pi_parrot_repeater
