Power supply identification needed
- Mudslinger
Hi Everyone, I have got this power supply as part of a job lot. Unfortunately some berk has scratched off the writing on the front, so I am unable to see what current rating it is.
I did try to search the model number and nothing truely believeable came up, although a couple suggested it might be 6-8Amps.
Can anyone confirm this? The physical size is less than my 3-5A although it is heavier.
- Call Sign: 26TM773
Re: Power supply identification needed
6 amp (Model number 1206 is the giveaway)
- 14CS06
Hello
Exact 6 A
Exact 6 A
- Mudslinger
Brilliant, thanks for confirming.
- Mudslinger
It was a bit dirty inside, I have managed to clean it out with Henry followed by some brake claener.
- 14CS06
- Buick Mackane
A bit dirty Looks like it was used to power the CW Set on the titanic
Change the caps and it'll be good for another 40 years.
- Mudslinger
It has come up as good as new, with 10 mins cleaning. I will change the caps, we have loads at work and that is within my limited ability.Buick Mackane wrote: ↑09 Nov 2021, 20:47A bit dirty Looks like it was used to power the CW Set on the titanic
- Buick Mackane
Never a bad ideaMudslinger wrote: ↑09 Nov 2021, 20:54It has come up as good as new, with 10 mins cleaning. I will change the caps, we have loads at work and that is within my limited ability.Buick Mackane wrote: ↑09 Nov 2021, 20:47A bit dirty Looks like it was used to power the CW Set on the titanic
As Claude mentioned later, probably 5-7amp, purely due to the continuous AND surge wording.
I think I've just got one amongst the 3 power supplies I bought for a tenner a couple of weeks back.
- Mudslinger
Either way it is better than the 3-5 which I have now.
Thanks for the info.
I just put a plug on, and tested it. it powers up and hums but there is no output. I will need to do some fault finding.
It hums because it doesn't know the words to the songMudslinger wrote: ↑10 Nov 2021, 21:18 Either way it is better than the 3-5 which I have now.
- Mudslinger
It doesn't even sound like much of a tune to be honest, just a monotonous drone.
- Buick Mackane
Well at least the primary is workingMudslinger wrote: ↑11 Nov 2021, 18:10 It doesn't even sound like much of a tune to be honest, just a monotonous drone.
