Looks like somebody emptied a Henry out on it beforehand!Mudslinger wrote: ↑09 Nov 2021, 20:39 It was a bit dirty inside, I have managed to clean it out with Henry followed by some brake claener.
Power supply identification needed
- Transwarp
- Call Sign: Viper
Re: Power supply identification needed
- Call Sign: 26TM773
Have you changed the caps yet?
- Buick Mackane
If you get stuck post in the repair forum. If you have a working transformer shouldn't be hard to get it up & running, Sureshot is the resident PSU Man for mods and repairs etc
- Mudslinger
I haven't had chance to have a proper look at it yet. I will "Borrow" some caps from work tomorrow and have a go at it over the weekend. There doesn't look to be much which can go wrong...
- Buick Mackane
Provided theres voltage from the transformer should be a pretty easy fix, Power transformers are pretty robust
- Mudslinger
Well at least half of the transformer must be working otherwise it wouldn't be humming.
I have some caps ready to fit, and some spare rectifier diodes, I just hope that it isn't the main transistor as it has an odd part number. It certainly isn't the usual 2N3055
99% of these I've fixed are just needing new caps.
- Mudslinger
Thats good news, I will have a crack over the weekend. My 3-5 struggles to power my PC-999 Grant but this supply should be much better in that regard.
- Buick Mackane
Resorvoir cap(s) could have shorted when it was plugged in, Maybe could have been reformed, But better swapped me thinks
- 14CS06
Hello
CB MASTER 5 A Constant à 7.5 A Surge Power Supply
https://www.ebay.fr/itm/144287089988?ha ... SwoRRhbGbR
- Buick Mackane
Best CB power packs were ''mr whoosh power houses'' Blue cases. And a picture of mr whoosh himself scribbled on the front panel..You just don't see quality like that anymore
- Mudslinger
When I said there was no output I appear to have a dodgy meter lead. It is actually putting out 24v
The output from the transformer inside is 36v (RMS)
I have some new caps which I will put in tomorrow.
- Buick Mackane
Sounds like a dodgy regulator
- Mudslinger
That was what i was thinking after doing a bit of internet "resurch". I am wondering of a cap has gone bad and caused the regulator to fail.
The regulator main parts seem to be a pair of transistors. One Large TO-3 type which has the part number BDW21 and is located on the heatsink, and another smaller TO-220 packaged device on the PCB which I am unable to read the numbers on until I remove it.
- Transwarp
- Call Sign: Viper
My disgusting pic for tomorrow on the 'Where's Weety ?' topic.Buick Mackane wrote: ↑12 Nov 2021, 20:00 Best CB power packs were ''mr whoosh power houses'' Blue cases. And a picture of mr whoosh himself scribbled on the front panel..You just don't see quality like that anymore
