Nice one, Not seen one of those in yonksTranswarp wrote: ↑12 Nov 2021, 21:02My disgusting pic for tomorrow on the 'Where's Weety ?' topic.Buick Mackane wrote: ↑12 Nov 2021, 20:00 Best CB power packs were ''mr whoosh power houses'' Blue cases. And a picture of mr whoosh himself scribbled on the front panel..You just don't see quality like that anymore
Power supply identification needed
- Buick Mackane
Re: Power supply identification needed
- Buick Mackane
Could be aye. I'm not all that familiar with PSU's, Don't work on them, But is the big heat sink fella not a pass transistor and the other the regulator ?Mudslinger wrote: ↑12 Nov 2021, 20:59 That was what i was thinking after doing a bit of internet "resurch". I am wondering of a cap has gone bad and caused the regulator to fail.
The regulator main parts seem to be a pair of transistors. One Large TO-3 type which has the part number BDW21 and is located on the heatsink, and another smaller TO-220 packaged device on the PCB which I am unable to read the numbers on until I remove it.
Wheres sureshot when you need him lol.
- Call Sign: 26TM773
Could have been modded for 24v hence why the writing on the front has been scratched off.Mudslinger wrote: ↑12 Nov 2021, 20:19 When I said there was no output I appear to have a dodgy meter lead. It is actually putting out 24v
The output from the transformer inside is 36v (RMS)
I have some new caps which I will put in tomorrow.
- Buick Mackane
But the voltage rating hasn'tChubbyChops wrote: ↑12 Nov 2021, 21:16Could have been modded for 24v hence why the writing on the front has been scratched off.Mudslinger wrote: ↑12 Nov 2021, 20:19 When I said there was no output I appear to have a dodgy meter lead. It is actually putting out 24v
- Transwarp
- Call Sign: Viper
Have a look again sir, it was less than 12 months ago since your last timeBuick Mackane wrote: ↑12 Nov 2021, 21:06Nice one, Not seen one of those in yonksTranswarp wrote: ↑12 Nov 2021, 21:02My disgusting pic for tomorrow on the 'Where's Weety ?' topic.Buick Mackane wrote: ↑12 Nov 2021, 20:00 Best CB power packs were ''mr whoosh power houses'' Blue cases. And a picture of mr whoosh himself scribbled on the front panel..You just don't see quality like that anymore
www.transmission1.net/viewtopic.php?f=2 ... 14#p536014
- Buick Mackane
i'd be investigating the over voltage before worrying about new caps, Just as well you never wired it to yer NOS Cobra to try it out
- 14CS06
Hello
Schematic PP-1206G
BDW21 , Si, NPN, 90, 45, 5, 15, 200, 15, TO3.
2N3055 , Si, NPN, 117, 70, 7, 15, 200, 20, TO3
Schematic PP-1206G
- Buick Mackane
Yeah i did recall something quite recently about them being mentioned in another thread,Transwarp wrote: ↑12 Nov 2021, 21:19Have a look again sir, it was less than 12 months ago since your last time
Well the schematic isn't a brain drainer....
- Mudslinger
Well according to the schematic the BDW21 is wrong, and it should be a 2N3055 (I have a new one here in my drawer) but isn't the voltage level set by the Zener diode?
To be honest there doesn't look to be much in there which could be wrong.
- Buick Mackane
The zener regulates the base current on the transistor,
Its a text book PSU Schematic, Yea the bare minimum of parts, No OV protection
Trash it.
This PS is crap by design.
Power transistor going south, full rectifier voltage goes to the radio. Poof, magic smoke, precious equipment is dead.
- Buick Mackane
You might want to consider knocking one of these up to protect your gear from future PSU Failures
https://www.electronicshub.org/crowbar-circuit/
Perhaps still use the suppliy's casing, but fit better/safer/more reliable components inside it?
- Buick Mackane
Be dandy with a simple mod or two
- Buick Mackane
This thread needs retitled and moved to the repair forum
