RM KL503 - Is it any good on SSB?
I'm thinking about getting a KL503.
Can anyone current or ex owners tell me if these sound any good on SSB?
Also, are they reliable if not over driven?
Re: RM KL503 - Is it any good on SSB?
They need a mod doing usually for ssb as they warble like
Boris Johnson
Boris Johnson
DELETE MY ACCOUNT
Add 12pf to C34 I believe
You’d have to double check online
DELETE MY ACCOUNT
It is indeed. You’d have to build a thermal reactive + adjustable bias into it
As the bias being low can obviously cause warble
DELETE MY ACCOUNT
Last minute decision, but I decided to amend my order & go for the KL505 instead.
Not sure if I've made the right decision or not?
Definitely! I’ve got a 505v it’s nearly 4 years old never missed
A beat
DELETE MY ACCOUNT
That's good to hear.
I bought the 505 without the fans, as I've got some decent Artic Cooling 120mm fans here.
I notice that the 505 also uses good old fashioned Bipolar Transistors as opposed to Mosfets as used in the 503, so the 505 will be more robust.
What sort of power are you seeing from yours with what drive, please?
I think 10w is about 230/250 on a dubious meter
I’ll have to plug it into my fx775 vector meter
DELETE MY ACCOUNT
No issues with mine at all once I worked out it needs a good psu to drive it.
I run it on ssb mode all the time, dont even change the switch for fm/am op seems to work fine with great audio reports so far.
- gmham
- Call Sign: 108TM154
Raising an old thread there guys but you still recommend the kl505 out of the current breed of Italian amps ? Looking for one just now if anyone knows of one going ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- prettypolly
- Call Sign: 26FB185
Rm kl703 35 watts in no1 setting 200 out no 2 setting 350 no 3 setting 475 watts out
