I wasn't sure what category to post this in seeing that its a PMR mic but considering its a mic in need of repair I thought I'd more likely get replies in the amateur radio section which is used on ham bands anyway.
I love this vintage mic, it has a nice feel to it but it doesn't work on any radio that I've tried it with, there is no PTT but PTT switch is good so its got to be something on the board. I can't see any obvious faults, no breaks in the tracks and all components look good and no breaks in the cable.
Does anybody have a clue of what the problem could be?
Anybody know anything about this mic?
- Werthers
- Werthers
Re: Anybody know anything about this mic?
I think the best course of action would be to de-solder the two transistors and test them with the multi meter for any shorts. Transistors are normally the main culprits to go bad.
- Werthers
I thought I'd come back to this mic as I didn't really bother with it the first time I opened it up.
I've pretty much tested everything now no bad transistors and switch is good. I don't expect there are any knowledgeable people left on this forum judging by the zero replies.
Unless this mic was to a very specific Motorola transceiver I don't know why it isn't working. I'm not going to chuck away a good looking quality mic like this I will just to disable the main board and rewire it directly to the PTT switch and mic component and have it working as a basic mic. All the original parts will be left inside.
