Decided to try out this configuration as it'll fit in my garden and can use a tree branch half way up for support.
The antenna is 124 ft long and covers 80-10m
Has anyone tried a similar configuration also was wondering how high off the ground should the end point of the antenna be.
EFHW 49:1 antenna setup advice
Re: EFHW 49:1 antenna setup advice
EFHW is bad and problematic antenna, but still better than no antenna.
Just hang it.
https://www.w8ji.com/long_wire_antenna.htm
Just hang it.
