I really wasn't sure whether to bother with this or not, but I have done. I know it's a bit of a dead band!
Just experimenting but not holding out any luck in being heard on any mode. It's a bit of a silly antenna I guess as it's not high enough for the length!
6 metre band slim jim
- Call Sign: 26TM718
Licence - British spelling
License - American spelling
Re: 6 metre band slim jim
I made three contacts on my 6m slimmy tonight, wasn't expecting that.
Slim jim is a waste of material wrappped in fictional gain over a j-pole,
They perform about the same & suffer the same issues with common mode on coax braid & mast that causes some people get decent results while others get poor results,
still nice to make an antenna & get contacts you did not expect.
W8JI
Don't worry about the gain, the common mode we can deal with by winding a choke. The point of the slim jim is it can be rolled up easily for portable use.
- Werthers
I've never liked the slim jim antennas myself. My mate did one for 4 meters and it was poor. I dislike the look and design of those antennas as well. I made a simple dipole for mine and that was good enough for me, I eventually replaced it for a CB antenna for 11 meter operations. I don't bother with 4 meters anymore. My homemade 2 meter dipole works brilliantly. I know some people will say that dipoles aren't the best and they'd be right but with limitations to what I can put up a dipole is good.
