QYT KT-8900D clone issues
- Otter
- Call Sign: 26TM439
I bought an Nktech 9800, thinking it was the same as as the KT-8900D and could be programmed by Chirp. When it boots up, the front panel even says KT-9800D. Well, using Chirp it reports that the radio didn't go into clone mode. I tried all the QYT variants, I tried another brand. Nothing. I can't find the original software for download or even for sale. Does anone have any ideas apart from programmig manually?
- Otter
Re: QYT KT-8900D clone issues
Well, I answered my own question. A lead from a CRT space U is not the same as a lead for the KT-8900D.
- MrWeetabix
- Admin
- Call Sign: 26TM175
glad we could all help haha
- Otter
Yeah, thanks everyone, the way I worked it out was really serendipitous. A local wanted to borrow my CRT space U programming lead and came to pick it up tonight. I said I tried it with a new radio and it didn't work with it. He had bought a radio like the one I bought, but with a lead and that lead didn't work with his space-u. So he borrowed my lead and I followed him home and borrowed his. Programmed all the PMR channels in with Chirp - no problems.
- Call Sign: G4RMT
I'm not being funny, but having looked up crt space u, it's clearly a totally different radio so not working is pretty much the expected result. Having the right connector is just a small part of the process. I've got dozens of programming cables and without the labels I eventually put on them, finding the right one was always tricky. Even more when some have to be pushed in all the way, then backed off a tiny amount or the connection isnt made. The ones with 2,3 or 4 circuit 3.5mm jacks are even odder with some many potential connection differences. Radios with virtually the same operating systems rarely work on the same programming cable. Even with so many cables I still end up buying new ones!
- Otter
These are both 3.5mm stereo jacks - I did look on the adverts first. There are 3 connections (Rx, Tx, Gnd) needed and 3 poles.
For audio at least - and the way the 3.5mm PCB connectors are connected you would expect the connection closest to the cable to be ground which just would leave 2 possible configurations. Quixiang make a lot of the radios, so I would expect most of the cables to be the same. OK, I was wrong, but when this is done I will know how to make the cables up myself. I've already detailed how to make your own CRE-8900 programming cable on this site
- Otter
It's 5V RS232, ground is closest to the cable, Tx data from the PC on the tip so must be Rx data in the middle. Standard 3.5mm stereo plug.
- Call Sign: G4RMT
My programming cable box is pretty full. Half have labels. Spent hours yesterday with a pile of radios trying to sort it. Appearance means nothing, neither does brand names, it's simply luck!
