MD UV380
weegeordie
Call Sign: 108TM020
MD UV380
Post by weegeordie »
Guys, apologies if this has been discussed before, I had a TYT Md380 and unfortunately its packed up, I did however back it up. Now ive ordered the updated version from martin lynch and sons the MD-UV380.
Question is How easy is it to transfer the stuff from the MD380 to the MD-uv380 as the newish one is VHF/UHF, i tried before and ended up sending it back
Anytone UV878II plus
Inrico T320
Nemo Me Impune Laccessit
2E0UCW
Call Sign: 2E0UCW
Re: MD UV380
Post by 2E0UCW »
A few suggestions:
1. Try opening the MD380 code plug in the MD-UV380 CPS
2. Open the MD380 code plug in a code plug editor [http://www.miklor.com/DMR/DMR-380-CPEditor.php] - export all the CSV files then import them into a blank MD-UV380 code plug
Motorola DM4600 ; Anytone 578 ; Anytone 868 ; Anytone 878 Plus
Whistler TRX-1 ; DV Mega ; Duplex Hotspot ; Zumspot USB
www.dmrguide.uk ; www.dmr-uk.net
