The scanner is back out of the box but has no frequencies stored in it. After a couple of hours I’ve found a few. Some I remembered. Hope these are of use to some of you
156.600 Mersey VTS (Old Mersey Radio)
167.810 Delta Taxis
168.125 Wirral Hackney
415.025 Unknown. Actually sounded Chinese
440.8625 Liscard / Cherry Tree Shopwatch
I’ll keep adding as I find more. If anyone has any to add than crack on
Latest Wirral/Liverpool Frequencies
- New User
Re: Latest Wirral/Liverpool Frequencies
Update:
85.360 71.860 Wirral taxi firm
145.750 2m amateur repeater Prestatyn
144.575 2m amateur repeater
- New User
Another update,
467.550 Ships crew
167.110 Liverpool taxis
467.550 Ships crew
- New User
Also coastguard (holyhead coastguard) 156.000. Keep posting freqs BertLFC23. Im just starting off and the stuff youve put up so far works really well!
Baofeng gt5-tp
Baofeng gt5-tp
- New User
Cheers mate I’ll dig out some more. I’ve just put a new antenna up so I’ll log some down and post them up. How many miles from Wallasey are you?
- New User
chester area. I do go to helsby hill, and the port so i get a better signal coz its right on the water.
Adding one that's active right now,
462.892125 - sounds to be a film crew
440.8625 is Chester zoo.
Is there much in Chester to listen to? I listen from St Helens, Runcorn and Warrington, I'm maybe just too far away.
