449 UK simple irritating noise?
- Andy
I used to listen quite a lot to the 449 MHz simple channels, but over the last few years there an annoying fast chuffing sound spoiling all the channels. It makes listening almost impossible. I suppose it's data of some description...?
'SOMEONE GET ME A SAW!'
Andy.
Andy.
- thelad
Re: 449 UK simple irritating noise?
Yep more and more DMR handys around now.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- Call Sign: 26DG01
It's digital.... You'll need an SDR to listen to it, unless you have access to a DMR radio and know the colour code etc. Some DMR radios have promiscuous mode which allow you to listen to the frequency regardless of what the talkgroup settings etc are. SDRs are available on the net for very little money, and the software is free (I used to use gqrx).
Sent from my GP300 using DTMF
Andys description of the noise doesnt sound like DMR. I've heard a similar chuffing sound elsewhere but not on 449,
- thelad
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
DMR Simplex (or input to a repeater) sounds like a fast chuffing noise. DMR Repeater sounds like a buzzing noise. Quite common to have DMR simplex on Simple UK Light frequencies.
Setting a CTCSS or DCS tone (if used, and if your receiver has this feature) may help you continue to listen to analogue.
- Mikel
Yeah, it's DMR simplex as you say, and becoming more frequent around here as well - very irritating!
- Andy
Yup, it sounds just like FDMA DMR in that link. Thanks. Bloody annoying though.
Andy.
Andy.
- Call Sign: 26DG01
I could be wrong, but I think the site you linked to isn't quite accurate. The bit in Section 3 says DMR is TDMA when used through a repeater, and FDMA when used simplex. This is incorrect, simplex mode still uses TDMA. FDMA is used by dPMR, which is not DMR. The link marked FDMA mode is actually TDMA, but only 1 timeslot instead of 2.
The SigID wiki has a page on DMR here
- thelad
Yes i spotted that myself.26mb04 wrote: ↑01 Dec 2019, 19:44 I could be wrong, but I think the site you linked to isn't quite accurate. The bit in Section 3 says DMR is TDMA when used through a repeater, and FDMA when used simplex. This is incorrect, simplex mode still uses TDMA. FDMA is used by dPMR, which is not DMR. The link marked FDMA mode is actually TDMA, but only 1 timeslot instead of 2.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Ah of course. I had forgotten that simplex dmr sounds very different to the saw type sound of a dmr repeater.
Slight hihack here. The example of an idling channel on the sigid wiki sounds like what I've heard on my local hospitals frequency. I'm not what an idling channel is. Voice or data?
- Call Sign: Cornelius
449 MHz Simple - is that UK-only frequencies? Like we here in Norway (and Sweden) have 444 MHz?
Or are you talking about 446 MHz?
- thelad
Here in the uk "449 Simple" or "Simple Light" are a handful of frequencies both Uhf and Vhf that Ofcom provide the use of for a fee of £75 for 5 years. You can only use a handheld up to a max of 5W, alot of UK Supermarkets and Businesses use them.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Ok, don't have that here exactly, but anyone can lease a frequency on Vhf or Uhf on a yearly basis, priced per unit in use (currently around £30 i think); handheld are max 5W, and base/car stations max 25W - repeaters are also allowed (priced higher per unit).
Though, not many private persons lease their own frequency here, mostly because many people here are active hunters, and they have their own frequencies on Vhf through their hunting-teams...
- Call Sign: 26DG01
Idling noise could just be residual data being sent across a repeater output (status requests, GPS data, random telemetry etc) in which case a DMR (voice) radio would be silent despite there being data on the channel. It could also be synchronisation packets, one of the drawbacks with DMR over dPMR is that DMR users MUST be synchronised with each other and the repeater (if used) or the whole thing falls apart.Goffy wrote: ↑02 Dec 2019, 10:30 Ah of course. I had forgotten that simplex dmr sounds very different to the saw type sound of a dmr repeater.
