President Madison homebase CB serial numbers
Re: President Madison homebase CB serial numbers
Looks good. Thought these might have been made in Japan like similar Uniden radios of the time , but they must have moved production around this time. I have the later MB8719 President and Uniden badged versions.
- Call Sign: KM6AOB
These photos are of the back of the 10 pin connector, the inside of the connector and where the wires are connected to a board. Maybe someone modified for a frequency counter.
Any thoughts would be appreciated.
I can't enlarge the photos to see the part numbers , but it looks as if it might be for a counter . Where does it connect to the main pcb ?
- Call Sign: KM6AOB
Here is a wider view of the inside, I can do better photos if I know what I need to share.
Still can't see that . Anyway . As I said . Once you see where it's connected , then you'll figure out what it does .
- Call Sign: KM6AOB
Since we can only post a 2mb photo per comment. I will try to do 3 from different angles and better resolutions to be seen easier. #1
- Call Sign: KM6AOB
Photo #2
- Call Sign: KM6AOB
Photo #3
The 75492PC is a display driver , so I'd say yes , there was probably an external counter display connected to it via that cable . Also , you've got a coax cable coming in to that pcb , which is presumably coming from the VCO circuit . If it was mine , then I'd probably rip all that stuff out .
S.
S.
- Call Sign: KM6AOB
Thank you so much for your help. Great suggestion about taking it out but for the moment I am going to leave it in the radio.
- Otter
- Call Sign: 26TM439
I wouldn't touch it tbh. The MM55110 is a PLL chip, and that radio needs at least one of them.cb4ever104 wrote: ↑13 Jul 2022, 10:24 The 75492PC is a display driver , so I'd say yes , there was probably an external counter display connected to it via that cable . Also , you've got a coax cable coming in to that pcb , which is presumably coming from the VCO circuit . If it was mine , then I'd probably rip all that stuff out .
S.
I saw that too , but I'd still rip it all out . Let it run with the uPD858 and buy a Maurer module for it . Just my 2c .
