I had one that was modified to electret, but the currebt that was drawn from the Up or down button connection meant it sometimes changed channel just because it felt like it. If you have a schematic for a reliable modification it would be really useful.
Lincoln mic problems
- Otter
- Call Sign: 26TM439
Re: Lincoln mic problems
That's a way to do it.
ChrisYou do not have the required permissions to view the files attached to this post.
Thread revival ! After poking about inside my Lincoln after discovering it has no tx audio i decided to put a scope on the mic - bang mic is at fault...
How on earth does the mic come appart ? Is there a hidden screw or clip somewhere other than the 3 on the back I cant see? I'm resisting the intention to prize the bas#### open with the big screwdriver but not sure how long I'll hold out!
- 13EL121
- Call Sign: 13DA121
No, the original Mic is no magic to crack it open. Maybe someone has fixed it with super glue? The original mic capsules seems to die all one by one. Had a lot of dead capsules in the last years.
- 14CS06
If the screw "posts" have been stripped or been snapped due to overtightening, then glue has been used in the past to keep the two halves together. You can try a Stanley knife and repeatedly run the blade along the crack. This might cut through a thin layer of glue.
However, if they've gone overboard with the UHU or superglue, then you may need to use a thin, flat blade to try and gently prise it apart.
If they've used loads of plastic cement (as used on Airfix planes), you're probably going to have to cause a bit of damage I'm afraid.
Convert to electret. Win-win situation.
- Otter
I'm sorry I didn't see this earlier. Thank you for posting it.
- 13EL121
Thanks all, yes expect it has been glued at some stage then. ill be as careful as I can and prize it open. Its dead as it is so nothing to loose I guess. Will report on progress!
cheers all, prized it open and the mic insert is indeed dead. are replacements available at all? done a quick google and they are all electret inserts listed on the 'bay. ta
- 14CS06
Hello
https://www.amazon.fr/Baosity-Microphon ... R1BR&psc=1
https://www.distronic.fr/capteurs-et-tr ... 0ohms.html
- 13EL121
An electret is cheaper and sounds better than the dynamic ones.
Thanks Claude!
electret conversion would be good but i like to swap mics on this radio as it goes out mobile some times so will stick with the dynamic
cheers all
cheers all
You can still use standard dynamic mics on the radio after the conversion. The electret mic can only be used on the radio , unless the other radios have been modified accordingly.
