Any interest in Philips FM1100/FM1000 radios?
Stmc84
Call Sign: M7STM
Re: Any interest in Philips FM1100/FM1000 radios?
Post by Stmc84 »
hi can anybody help me out with the 4m conversion for the fm1100 bin file or point me in the right place to find out any help appreciated
73`s steve
df2tb
Call Sign: DF2TB
Post by df2tb »
Steve,
you find the necessary information plus the files here: https://a63.veron.nl/download/pa4den/fm1200.html
Andreas DF2TB
shugster
Post by shugster »
Hi
I am on the look out for UHF fm1000s.
I help at a museum which restores buses and the fleet radios on a lot of the Glasgow ones were trunked fm1000s. Obviously these are no use now, but look the part in the restoration.
I recently swapped in 2 UHF ones and swapped modified the heads to look correct. I had the receive programmed on the PMR446 frequencies so that the buses could listen in on the museums net, so that some radio traffic was heard. It also meant we could use it for reversing buses around.
Obviously transmit was disabled.
This has proved immensely popular and the owners of the other buses that had radios are looking for the same!
So I am on the hunt for 6 working UHF FM1000s... (some Storno 600s or just control heads too!)
Anyone got anything available?
Regards
Hugh GM0HSC
pienari
Call Sign: 56la422
Post by pienari »
Hi.
What type head was on those FM1000 radios?.
I use keypad head all my 4m and 70cm radios.
Mobile. Ham concorde3, Megawatt 4000,Zetagi B550p.
Home. Colt Excalibur SSB , 2el Quad, Diy ldmos amp 1.6kw pep.
pienari
Call Sign: 56la422
Post by pienari »
I bought 2pcs france model 4m FM1100 radios few weeks ago.
Both was same strange type cpu board, but i got both moded.
Tone cpu mod can not be used.
Rx sensitivity 0.22uV @ 70MHz
I measured tx power @ 70MHz
30W @ 12.5V
42W @ 15.0V
pienari
Call Sign: 56la422
Post by pienari »
Today i measured 4M FM1100 vcc voltage from the boards and there is too much resistance in boards and wires.
PSU was set at 15v and i measured 12.9v in full power from amplifier module.
I think i need to solder few wires to board and test again.
