+10kc jump for stalker9
cb4ever104
Re: +10kc jump for stalker9
Post by cb4ever104 »
dt307 wrote: 21 Mar 2018, 10:59thanks sammy nice to see you m8
Hi Chris ! Good to see you too m8 !
After 21 years in Spain I now find myself stuck back here in the UK :crazy: Haven't been able to do any radio work so my brain's getting rusty :)
Raverrst
Call Sign: 26LW29
Post by Raverrst »
Does it matter where the resistor goes within the length of wire in both cases? or can it go anywhere i,e in the middle of the 8v wire
Radios, radio!!
astradyne
Moderator
Moderator
Post by astradyne »
Raverrst wrote: 21 Mar 2018, 11:45 Does it matter where the resistor goes within the length of wire in both cases? or can it go anywhere i,e in the middle of the 8v wire
I've always solderd the resistor directly onto the pin on the IC and run a wire from the other side of the resistor directly to the switch.
cb4ever104
I usually solder half the wire to pin 9 . Then add the resistor in the middle (with heat shrink) and then more wire to the middle terminal of the switch . The other ends of the switch will be 8V and earth . That way the resistor will always be in series regardless of what the switch position is .
NightProwler
Call Sign: 163TM186
Post by NightProwler »
Nice :thumbup:
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix »
dt307 wrote: 21 Mar 2018, 11:07 CAN A MOD EDIT THIS PLEASE AS I CANT!
solder a red wire WITH A 1K RESISTOR IN SERIES to constant +8v on front of pcb right by the swith or (pin 16 of either of the 4008 adders will do ic5/6 (9dx) ic301/302(fdx))
THANKS
Done, let me know if I've messed it up at all. :thumbup:
