Did you try it on AM, when I say the needle moves, I meant the receiving rig, not your, have you turned the pre-amp off. Turn the pre-amp so it is out of the equation for the moment (and confirm you have done this). Try it on FM (and confirm you have done this). Does the receiving rig get any thing, i.e. carrier but no audio or no signal whatsoever (confirm which this is).wrecker wrote:Well my Wilson 1000 is connected to the ant socket and the patch lead i made is connected to the rtx socket and radio, the needle moves when keyed and it receives perfect.
Don't come back until you can answer those questions.
