External Antenna on DP3600
- radiogaga
- Call Sign: 26TM399
Anyone successfully added an external antenna to the DP3600? What fitting adaptors are necessary? Thanks
30TM399 Northern Costa Blanca
Re: External Antenna on DP3600
It's a sma fitting, same as the quansheng and wouxun type Chinese handhelds etc.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- radiogaga
SMA Female. Thanks... Should have just created a list of Q's for you by PM
Like these: http://www.ebay.co.uk/itm/like/40066980 ... 108&ff19=0
I use this type
http://m.ebay.co.uk/itm/350376531549?nav=SEARCH
Just incase the collar on the other type gets in the way when connecting it to the radio.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- radiogaga
Thanks for that I'll order one up. If you get a chance re the PM I'd be very grateful.scottyboy wrote:I use this type
- chin913
- Call Sign: notafullone
Warning: Dates in Calendar are closer than they appear.
https://www.youtube.com/user/mrblogger913
https://www.facebook.com/groups/furnesshamradio/
