Grant PC 999-AC No receive
- astrolab
- Call Sign: F0GIQ
Hi,
My Grant PC 999-AC have no RX in all modes , ( no green led) .
TX is OK, BF is OK , P.A is good also , if you know this problem, thank you.
73/51
73/51
CB's collector-IC 706 MK II-FTM 350 R/E Ant X300-FD3-Black Pirate....
Re: Grant PC 999-AC No receive
Are the connections in your mic okay?
- Mudslinger
Does it receive with the microphone disconnected?
It should do, and if it doesn't there is likely a component gone down somewhere.
- astrolab
- Call Sign: F0GIQ
Thank you
Microphone is Okay, all capacitors 10 volts are changed , and green led also, by security.
Yes a componant is surely down somewhere
Have you changed TR35 the 2SB525C transistor, it's the RX switching transistor.
- astrolab
- Call Sign: F0GIQ
Good Morning Zephyr,
No, i have changed IC 4 (5218)
Now, TR 35 , 2SB 525 C RX working on AM-FM, but no in SSB , led green working fine also
Many thanks for your aid.
- Mudslinger
I am pretty sure on of my Grants suffered a similar issue.
I think one of the Diodes in the switching circuit had failed (D12 rings a bell?)
- astrolab
- Call Sign: F0GIQ
Thanks, anyone know the référence of this diodes (eg D 24) ?
73 Michel
73 Michel
- Mudslinger
Not sure what the number is, but the one that failed in mine looked like this.
http://www.ebay.co.uk/itm/1N34-GERMANIU ... 19ea2c3ea8
Nick Black Spirit might be able to help you furrther as it was he who repaired my radio.
D24 is IS2075K or an IN4148.
- astrolab
- Call Sign: F0GIQ
Hi,
Now i have no RX on SSB only, green led light OK, but no receive in SSB (LSB/USB) ,TX is ok .
In SSB RX , TR50 is very hot
I think that is switching RX-SSB , but what is components of this circuit ?
Have a nice day
Have a nice day
- cjay
- Call Sign: cjay
You need to be checking voltages, TR50 is part of the voltage regulator and AM modulation circuit, if it's getting hot then it's dissipating too much power. Check TR47, the 2SB754 and TR47, the 2SA473, they may be leaky or short circuit which would cause TR50 to overheat.astrolab wrote:Hi,
Have a nice day
- astrolab
- Call Sign: F0GIQ
All goods , no short circuit .
TR50 does get very hot it's got a 1w 47ohm resistor going to 0v GND and that also gets hot.
cjay, I think you mean TR47 and 48.
- astrolab
- Call Sign: F0GIQ
TR 47 TR48 and TR 50 all right.
