Uniden 2830 Squelch problem
Hi i have a problem on my 2830 there is no squelch whatsoever no auto squelch either has anyone any ideas what could be the cause regards kev.
- Bigdave
Re: Uniden 2830 Squelch problem
You aint hit the pa button,just above the squelch ave ya m8........................
26 TM 1248
WINNER of INB4TL, the big battle edition 16/07/23
OFTEN IMITATED,BUT NEVER INTIMIDATED.
WINNER of INB4TL,the no interest edition 18/03/24
No it was constant static S3 i just changed the capacitor as per this link as my fm/am receive was gone too all problems cured including the squelch problem one happy chappy!!!
- Otter
- Call Sign: 26TM439
What link?
Sorry i was posting in 2 threads http://forums.qrz.com/archive/index.php/t-359364.htmlOtter wrote:What link?
Nice to know.
- Atomic
Wished I didn't have much static lol , s3 is nothing , I get slammed with 5-7 of white noise most days
- cjay
- Call Sign: cjay
It'd be worth replacing all the rest of those crappy capacitors too then.KEV07 wrote:No it was constant static S3 i just changed the capacitor as per this link as my fm/am receive was gone too all problems cured including the squelch problem one happy chappy!!!
Sorry i didnt explain the S3 was not actual receive static but electrical static caused by the failed capacitors even my friend who is less that a mile away was still only hitting me with S3 now the new cap is in there back to 30+Atomic wrote:Wished I didn't have much static lol , s3 is nothing , I get slammed with 5-7 of white noise most days
- Otter
Best thing with those 2830s and early Lincolns is to replace all the 10V capacitors. I've seen five failed ones in a single radio. Don't forget the one on the display board, which stops the display from coming up when it goes short.
Hi Otter what value capacitors should be used for replacing them? cheers.Otter wrote:Best thing with those 2830s and early Lincolns is to replace all the 10V capacitors. I've seen five failed ones in a single radio. Don't forget the one on the display board, which stops the display from coming up when it goes short.
- cjay
- Call Sign: cjay
Same value as the ones in there, the uF value anyway. The voltage rating doesn't matter so much as long as it's as high or higher than the original. You can buy caps with better ratings, 105 degrees centigrade, 125 degrees, even 150 degrees, that will last longer but you have to watch out for the physical size of them.KEV07 wrote:Hi Otter what value capacitors should be used for replacing them? cheers.Otter wrote:Best thing with those 2830s and early Lincolns is to replace all the 10V capacitors. I've seen five failed ones in a single radio. Don't forget the one on the display board, which stops the display from coming up when it goes short.
The nasty little back to back caps you found causing the squelch/noise problem should be replaced with a single part, a bipolar capacitor.
I swapped the 2 x 47uF 10V electrolytic caps for a 22uf ceramic will this be ok? I also think the FM receive is a little low is there a cure for this?cjay wrote: The nasty little back to back caps you found causing the squelch/noise problem should be replaced with a single part, a bipolar capacitor.
- Otter
Possibly the 10V capacitor on the FM board, and if it has gone the 10R resistor on the board may have burnt out.KEV07 wrote:cjay wrote: I also think the FM receive is a little low is there a cure for this?
- cjay
- Call Sign: cjay
Yeah, two 47uF caps in series have an effective value of around 23.5uF, 22uF is well within the tolerance for that.KEV07 wrote:I swapped the 2 x 47uF 10V electrolytic caps for a 22uf ceramic will this be ok? I also think the FM receive is a little low is there a cure for this?cjay wrote: The nasty little back to back caps you found causing the squelch/noise problem should be replaced with a single part, a bipolar capacitor.
As for FM receive being low, sorry, don't know but there is one of those nasty caps on the FM board too. If the radio came to you with that fault is it possible it's been tweaked about to try and 'repair' the squelch fault?
