Superstar mic wiring
timbob58
Call Sign: 26tm957
Post by timbob58 »
It may be simple for some people and if so , can someone tell me what wires go to what pin , on a superstar 360 fm . I have 5 wires , braid white blue red and yellow . ( 4 pin plug ) . Cheers .
bigpimp347
Re: Superstar mic wiring
Post by bigpimp347 »
it's not a case of what wires you have.
it's what the wires are doing in the mic end :)
not everyone wires the mics the same..
the radio is Uniden wired so easy to do with just three wires.
it depends what mic it is, and where the wires go in the mic.
assume
red is TX
black is RX
braid is earth
yellow is audio
blue is a second earth.
or totally different :)
Dragonfly
Call Sign: 26TM363
Post by Dragonfly »
If its a flat mic try
1 - Braid
2 - Yellow
3 - Red
4 - Black
You may be able to put the Blue on the same pin as the braid .
Coppernob
Post by Coppernob »
What microphone is it ?
timbob58
Call Sign: 26tm957
Post by timbob58 »
It says superstar on it . It has braid , white , yellow , blue , red , and it doesnt look touched inside . Cheers .
Buick Mackane
Moderator
Moderator
Post by Buick Mackane »
If its just a standard mic its easy to figure out which wire does what just by looking at the PTT switch, So a close up pic of the switch might help, Or configuration of the wiring can be worked out using a simple continuity tester.
Coppernob
Post by Coppernob »
Plug solder points facing you
Notch on bottom,starting bottom left ,I will call this pin 1,work round in a clockwise direction and finish opposite where you started . I will call this pin 4.
So... Notch on bottom,solder pins facing you .
Pin 1-Red
Pin 2--White
Pin 3-Blue
Pin 4- Screen
Think this is right.
Let me know either way ,regards Coppernob.
Edit ! Yellow not used(I Think)
timbob58
Call Sign: 26tm957
Post by timbob58 »
Coppernob wrote:Plug solder points facing you
Pin 1-Red
Pin 2--White
Pin 3-Blue
Pin 4- Screen
just done it,, solder side, pin 1-screen, pin2 white audio, pin3 red tx, pin4 blue rx, and the yellow as u said not used ,, :)
timbob58
Call Sign: 26tm957
Post by timbob58 »
:) :) thanks all for your comments :) :)
JDog
Call Sign: JDog
Post by JDog »
/storage/emulated/0/Download/4-pin CB connector.jpg
Click one pic and it will rotate to full view.
NightProwler
Call Sign: 163TM186
Post by NightProwler »
After 10 years I should think/hope he has done it by now ;)
