Sunderland airshow 2012
- bpoolfc95
Hi all, I've got the frequencies in my scanner for the display teams, ie red arrows, bbmf, the blades, but does anyone know of freqs for the individual aircraft such as miss demeanour and the typhoon. Many thanks.
- Minus1
Re: Sunderland airshow 2012
Bit confused by your request. Why would singleton aircraft have an air to air freq?
If you mean the organisers frequency, according to a post on this forum last year, it was 121.175
This is said to be "CAA Short-term / Events primary"
- bpoolfc95
Two years ago, when i only had the cheap £15 scanner that you manually tune, i picked up the f86 sabre and the harrier. The harrier was going on about lining up with the lighthouse, the Cliffe park one. Im wondering about the comms that ive listed above. Mind you them scanners are horrible and very hit and miss so no way i could get the actual freqs.
all aircraft will transmitte on 121.175 this year to call up and run in for show and even do there display on the freq unless they will use there team freqs and i have listed them all for this year even the role demo on the thred on northeast
- bpoolfc95
Great thanks. Let's just hope the weather is decent.
- MrWeetabix
- Admin
- Call Sign: 26TM175
