Hope this helps solve your question... Courtesy of the CB Museum.bluas wrote:do the dx27 have single wire twisted up the side and a stinger to adjust swr, had a root in the loft and found a 6ft and 7ft fire stick plus think a dx27 amog,st others. cheers j
dx27 1980s mobile antenna...
Re: dx27 1980s mobile antenna...
- scottishtommy
iv had the dx 27 in the past and yes it was good before that i had the dv 27 and no that was not any good but am now using a steell 2 part 1/4 wave whip in my loft stuck out through a tile and its around 35 feet in the air and it works better than anything iv tried and works great when i kick 200 watt into it
- Has thanked: 1 time
- Been thanked: 3 times
I had a dx27 on a biscuit tin in the loft in the 80s. It was probably the best loft antenna I ever had and I wish I'd kept it. I'm considering going back to CB and loft antenna is my only option at the moment. The dx absolutely kicked arse.
- DX-Digger
- Call Sign: TM205
- Been thanked: 5 times
Wow this old thread you resurrected is 15 years old.
Is this a forum record????
I still have a dv27 upstairs somewhere lol
I just searched on "dx27"
Here's a Sirio clone.
http://www.kcb.co.uk/contents/en-uk/p19 ... Log_5.html
The spec looks slightly short of the top of the UK 40:
"Frequency range: 26.7 … 27.7 MHz Tunable"
Channel 40 = 27.99125mhz
