Hi, I was in Edinburgh for a few days and was able to scan these frequencies.
Who can help me identify them?
146,52500 2m DMR ?
147,63750 2m NFM ohne
148,57500 2m NFM ohne
153,02500 2m NFM ohne
153,35000 2m NFM ohne
153,37500 2m NFM ohne
156,00000 2m NFM ohne
156,30000 2m NFM ohne
156,55000 2m NFM ohne
156,57500 2m NFM ohne
156,60000 2m NFM ohne
156,62500 2m NFM ohne
156,80000 2m NFM ohne
156,85000 2m NFM ohne
156,95000 2m NFM ohne
157,22500 2m NFM ohne
157,85000 2m NFM ohne
158,78750 2m DMR CC 3
158,88750 2m DMR ?
159,60000 2m NFM ohne
160,60000 2m NFM ohne
161,82500 2m NFM ohne
162,03750 2m NFM ohne
162,18750 2m NFM ohne
162,57500 2m NFM ohne
162,71250 2m NFM ohne
162,72500 2m NFM ohne
162,73750 2m NFM ohne
162,78750 2m NFM ohne
162,90000 2m NFM ohne
163,03750 2m NFM ohne
163,05000 2m NFM ohne
163,06250 2m NFM ohne
163,16250 2m NFM ohne
163,20000 2m NFM ohne
163,22500 2m NFM ohne
163,28750 2m DMR CC 3
163,38750 2m NFM ohne
163,91250 2m NFM ohne
164,06250 2m NFM ohne
164,10000 2m NFM ohne
164,17500 2m NFM ohne
164,45000 2m NFM CC 7
165,06250 2m NFM 71,9
165,37500 2m NFM 127,3
165,45000 2m NFM 67,0
165,87500 2m NFM 77,0
166,26250 2m DMR ?
166,28750 2m NFM CC 7
166,31250 2m NFM 67,0
166,90000 2m NFM 103,5
167,06250 2m NFM 77,0
168,12500 2m DMR ?
168,81250 2m NFM ohne
172,90000 2m NFM 203,5
175,78750 2m NFM ohne
175,82500 2m NFM ohne
177,31250 2m NFM ohne
177,37500 2m NFM ohne
177,53750 2m NFM ohne
177,56250 2m NFM ohne
177,57500 2m NFM ohne
177,60000 2m NFM ohne
177,68750 2m NFM ohne
177,71250 2m NFM ohne
177,72500 2m NFM ohne
177,82500 2m NFM ohne
177,90000 2m NFM ohne
177,91250 2m NFM ohne
177,98750 2m NFM ohne
178,05000 2m NFM ohne
178,07500 2m NFM ohne
178,15000 2m NFM ohne
178,17500 2m NFM ohne
178,22500 2m NFM ohne
178,23750 2m NFM ohne
178,25000 2m NFM ohne
178,31250 2m NFM ohne
178,35000 2m NFM ohne
178,40000 2m NFM ohne
178,42500 2m NFM ohne
178,46250 2m NFM ohne
178,52500 2m NFM ohne
178,57500 2m NFM ohne
178,67500 2m NFM ohne
179,22500 2m NFM ohne
179,51250 2m NFM ohne
179,67500 2m NFM ohne
179,73750 2m NFM ohne
401,20000 70cm DMR CC 7
401,30000 70cm DMR CC 1
Edinburgh Scan 2024
Re: Edinburgh Scan 2024
Various marine channels
158,88750 2m DMR ?
Pagers
Short term hire, could be anyone
Business radio's, possibly bus companies
158,88750 2m DMR ?
Pagers
- Call Sign: C01337
Im scanning on a baofeng rt5r in the stenhouse area in Edinburgh not picking up very much and hints or tips? Thank you
Is it one of those radios you need to know the details first, as opposed to being able to search and find things? A lot of people seem to be buying two way radios that don't search or give the tone, colour code, talkgroup or slot then need to ask others. An Anytone 878 is one of the few two ways that searches, scans and decodes the dmr details it finds. It doesn't show up the CTCSS or DCS tone, but will let you listen to everything on it. Unless you only want to listen to amateur, marine, analogue pmr, you won't hear much else on that radio. A lot is going or is digital.
- Call Sign: 108AT106
158,78750 CC 3 and 163.2875 CC3 are the same OP as thats a split on PM/Business radio base mobile . Check WTR bit a lot are withheld which is why i think ofcom are going to axe the register. Good Luck
Regards
Regards
Kind Regards
Rab
Rab
