How to stream SDR over the internet ?
LondonCbRadio
Re: How to stream SDR over the internet ?
Post by LondonCbRadio »
dc260 wrote: 18 Mar 2024, 23:09
LondonCbRadio wrote: 20 Sep 2023, 16:13 Openwebrx saying no sdr devices. I'm using ubuntu.
Do make sure you have the up to date drivers installed for it and not the default ones.
Is there a step by step guide ? It's a rtl rtl2382u blue case. It was very cheap off ebay. Been told it could be a fake but would that stop it from working with websdr ? Any help would be great as it will benefit every one that listens as i'm almost 600 feet above sea level.
dc260
Post by dc260 »
LondonCbRadio wrote: 20 Mar 2024, 14:21
Install rtl sdr drivers
sudo apt-get install rtl-sdr
should installl all the necessary tools
You can test the device is working with the following command
rtl_test
To install openwebrx
https://www.openwebrx.de/download/ubuntu.php
run following commands consecutively
wget -O /usr/share/keyrings/openwebrx.gpg https://repo.openwebrx.de/openwebrx.gpg
echo "deb [signed-by=/usr/share/keyrings/openwebrx.gpg] https://repo.openwebrx.de/ubuntu/ jammy main" > /etc/apt/sources.list.d/openwebrx.list
apt-get update
apt-get install openwebrx
LondonCbRadio
Thanks i'll give it a go when i get some time.
NMPEL
Has thanked: 1 time
Post by NMPEL »
The problem is too many sdr's and not enough talking. There is little point in having tons of ways to listen when the numbers are not there. We need to find ways to bring the nunmbers up.
Agent 48
Been thanked: 1 time
Post by Agent 48 »
Thats very true...
Its the same with DMR tons of talk groups but nobody actually talking. There is no point in having tons of channels when there are only a tiny handful of people that come on every now and again.
