7900
109 Jim
7900
Post by 109 Jim »
i was given a 7900 and as per the s meter is way high , with the software the usb/lsb rssi dont seem to be doing anything when i change the values , what am i doing wrong
109 Jim
Re: 7900
Post by 109 Jim »
i assume by the lack of answers the software is not the way to go
Pluskat
Call Sign: 16op234
Re: 7900
Post by Pluskat »
I have the 7900V....in the engineer menu you can change a lot.
But if you not know what you are doing it can be dangerous.
109 Jim
Re: 7900
Post by 109 Jim »
its the 7900 i have and i thought you could change the s meter with software
