Converting Hp Server Power Supply’s..
- Raverrst
- Call Sign: 26LW29
Hi all. Been using a Hp Pl18 server power supply for some months now in the shack, it seems to work really well, no rf noise etc. Something I am finding is when I plug in the mains im getting quiet a “snack” as the supply powers on, the method iv followed to mod the supply to switch on was to just loop a wire between the first and forth pins on the board, I see other methods use two 1k resistors to allow the supply to switch on! Anyone know the need for the resistors? Would this add a more gentle switch on?
Radios, radio!!
- Buick Mackane
Re: Converting Hp Server Power Supply’s..
Well i have two HP 1200FB Power supplies both started up via a 560 ohm resistor and don't have any issues with them, Only one way to find out. Try starting them up via resistors
