That quiet hiss with a far off copy
(I thought was far)
was magical back then.
The legalization in 81 when I was 14 saw FM and a horrible crackle, but squelch could remedy it, and the door was open to everyone, kids, teenagers, blokes and old farts, all vying for them 40 channels ,
I witness a lot complaining about it now , mic keyers, music players, bucket mouths etc, yet moan about the lack of people on air ,
Well. It was certainly interesting back then.
Signal reports and radio's used over and over gets a bit tedious at times.
(Did you see what I did there with the over and over,? ,,,,,Over, ,,,, beep. )
Having a few rigs back in the day but not checking SWR apart from the "its ok mate, you can use the power meter" advise. Is probably why I had a few rigs
Went from a Magmount on a biscuit tin to a dipole I fitted to the metal gutter.
Then suddenly around 1984 I was off air.
Only to return last year 37 years later on a nostalgia trip, as an old fart, talking to other old farts about signal strength and what radio and antenna was used FFS
So what's your CB story ?
Did you stay on since those halcyon days and what are your opinions if you did ?
