CRT SS6900N potentiometer nut removal
Hi, Does anyone what tool you use to remove the locking nuts on the potentiometers. Need to remove the front panel.
Thanks.You do not have the required permissions to view the files attached to this post.
- Call Sign: Lemmy
Re: CRT SS6900N potentiometer nut removal
Nose pliers
- Call Sign: Lemmy
I made one by myself.
Take metal pipe with diameter right for the nut.
Take metal file and make "crown" with 4 tabs fit the nut.
If you can't unscrew that with pliers, maybe it's glued.
They don't look glued but who knows. Anyway thanks for the suggestion i'll give it a try.
- Call Sign: AMC45
I had some made up in by a cnc place proper
Worth the outlay, I looked for weeks for stuff
Online couldn’t find any.
I’ve got three one for mic sockets
One for vol/sq etc
One for mode switches on strykers etc
One for vol/sq etc
