How much QRM Do you suffer from ?
- Buick Mackane
I live in a sea of it, 90% of it comes from the heating system the council installed on the estate about ten years ago, Uses big externally mounted fans.
Till a few weeks before xmas 40m was my least effected band with a constant S-5 Of mush, But at certain times it's started creeping up to an S7.
20m Is my most effected band, At worst it's S-8
15m around S-7
11m the same
10m Around S-5
All the above figures are with the preamp off.
Sometimes wonder why i bother.
Curious as to what other users experience on the HF Bands
15m around S-7
11m the same
10m Around S-5
Princes in exile raising the standard Drambuie
Re: How much QRM Do you suffer from ?
CB - none. 5/8 vertical.
6-20m none. Multi element Yagi antennas 15-25m over a ground.
30m s2-3 band static on full size GP
40m s3-4 band static on full size GP
80m s4-6 band static on full size GP, none one k9ay and Beverages.
I don't even use NB nor ANL.
It took some time to get off all noisy crap around, but was worth it.
- Buick Mackane
You should think yourself lucky with those figures chris.ch25 wrote: ↑03 Jan 2023, 15:19 CB - none. 5/8 vertical.
Iv'e camped in the middle of nowhere and had QRM, Seem's to follow me around
I have station on countryside.
After Polish "Ofcom" intervention on my call I had noisy 15kV transformer replaced a few years ago, one or two insulators on powerline 300m away, fixed leaking grounding.
Leaking 15kV insulator can make 59+ noise really far.
Noisy gear in my house I trashed myself
- Buick Mackane
I Wish our ofcom were that effective, They're only interested in hunting down people who don't have a TV License
April 2012 one day it started like that:
After their intervention all quiet.
It goes up and down here,day time around s2 and evenings it can be higher when people turn tv on. Christmas lights from a neighbor made it go up to s7.
- Buick Mackane
About time radio manufacturers started incorporating QRM Eliminators into their radios, Although i'm not totally convinced they are that effective,
There is a conspiracy theory going about that CB Radio is targeted deliberately due to the fact that the GOV can't control it. I'm talking in terms of freespeech. But for it to look good all HF is wiped out. Not saying it's true but it makes sense.
- Buick Mackane
Sounds far fetched to me considering CB is rarely used these day's the same folk who spread that conspiracy probably think the earth is flat and our minds are being controlled by 5-G SignalsLondonCbRadio wrote: ↑04 Jan 2023, 11:41 There is a conspiracy theory going about that CB Radio is targeted deliberately due to the fact that the GOV can't control it. I'm talking in terms of freespeech. But for it to look good all HF is wiped out. Not saying it's true but it makes sense.
under s-1 across HF.
1/2 sized G5RV at the minute.
though to be fair, its daylight and all the Christmas LEDs are off now!
- chazwozza
- Call Sign: 26CD172
None you would think my radio was broken
- Call Sign: 26TM718
Some people with very low QRM, may have radios which aren't as sensitive as they used to be!
Licence - British spelling
License - American spelling
- chazwozza
Brand new 7300 pretty sensitive
- ghost123uk
- Call Sign: 26TM953
On 11Mtrs I get S9 most of the time
It is not from my house as I tested by running off a battery.
It is from the aerial, not the mains.
I tried a (new) QRM eliminator. I spent a good few hours / days experimenting with it. It made no difference. This is 90% certain because whilst they are OK at "nulling out" a specific source of noise ( a TV or Wi-Fi repeater etc) but not any good when it comes to a general "mush" of noise coming from multiple sources.
So, if I want to play radio "properly", I go about 2 miles away, out of the village in my VW camper and avoid the QRM that way.
What ever happened to the time when any electronics equipment sold had to pass a test to prove it did not emit spurious RF
