i have an aor ar8200 i used years ago, it has a fault where the bottom row of buttons dont respond to them being pressed, the enter button is on that row and it is now useless for me unless i can get it repaired,
does anyone know of a place to get these repaired or can anyone on hear do it?
failing that i may sell it for spares/repair.
thanks.
AOR AR8200 Repair?
AOR AR8200 Repair?
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- dcwuk
Re: AOR AR8200 Repair?
I believe this is AOR UK LTD`s address and phone number maybe a quick call will help to find a repair agent
AOR (UK) Ltd
Unit 9 / Dimple Mill
Dimple Road
Matlock
Derbyshire DE4 3JX
01629 581222
rgds
dcw
AOR (UK) Ltd
Dimple Road
Matlock
Derbyshire DE4 3JX
01629 581222
rgds
dcw
Rimarton Limited (AOR-UK) doesn't exist as such now. Distribution/spares for AOR are handled by Waters & Stantondcwuk wrote:I believe this is AOR UK LTD`s address and phone number maybe a quick call will help to find a repair agent
AOR (UK) Ltd
- jaybranch
This might help you... seems to be a fix to solve your issue:
http://www.tarapippo.net/aor/8200-keypad.html
73s
Jay
73s
Jay
73 & 88
26TM1979
AOR3000A
Yupiterus (a lot!!)
VX-7R
Lowe HF 150 & 225
TS850 SAT
A longwire & GR5V
26TM1979
AOR3000A
Yupiterus (a lot!!)
VX-7R
Lowe HF 150 & 225
TS850 SAT
A longwire & GR5V
jaybranch wrote:This might help you... seems to be a fix to solve your issue:
73s
Jay
Had same prob with my 8200 mk3, used the fix as detailed in the link above and it works great, just be careful when you open the case because the contacts going to the battery compartment can become detatched from the solder very easily, apart from that its a 10 min job that works like a dream
Uniden BTC15X,
Uniden 3500XLT
PlanePlotter with a RTL 1090 Dongle, Sharer "Pn"
Uniden 3500XLT
thanks for that, i mite just give it ago when i get a minute.
1 of the battery contacts has a bit of corrosion and rusty as it had batteries left in it for a while when not in use.
but will see how i get on.
thanks.
thanks.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
73s
Jay
spot on, this worked a treat and as said was only a 10 minute job.
thanks
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- jaybranch
scottyboy wrote:jaybranch wrote:This might help you... seems to be a fix to solve your issue:
73s
Jay
thanks
Nice one fella!
73 & 88
26TM1979
AOR3000A
Yupiterus (a lot!!)
VX-7R
Lowe HF 150 & 225
TS850 SAT
A longwire & GR5V
26TM1979
AOR3000A
Yupiterus (a lot!!)
VX-7R
Lowe HF 150 & 225
TS850 SAT
A longwire & GR5V
Hello all
Looking for a replacement keyboard for the AOR 8200MKIII as the enter key has fallen off, anyone help?
Thank you
Thank you
