Warrington 455.750
- Call Sign: mm12
Re: Warrington 455.750
I've found 440.225, 455.775, 453.9875, 445.6125, 455.750, also 456.975 (a warehouse or distribution centre, but which, there are loads around here) all on DMR, on 456.400 on NFM which is possibly a shopwatch in St Helens
You still haven't yet said which scanner you have. Some have continuous from 25 to 1300 mhz, some have gaps.
- Call Sign: mm12
Bottom of page 1 the list with freq, ICOM IC R5
Exact same text posted by someone else on another bulletin board......
'carlos' using an R5 but can determine that a dmr freq is a warehouse or distribution centre?
He can listen to paging data and say it's an 'airport'?
Anyone else find this rather suspect?
- Metradio
- Call Sign: G7HID
Nowadays it is not unusual
Mike
Mike
- Call Sign: mm12
Hi everyone, is anyone having any luck receiving this? please PM or reply thanks
- Call Sign: mm12
Hi all I have been doing some research as my laptop has packed up …. RADIO SCANNER - UNIDEN BEARCAT UBCD 3600XLT DIGITAL & ANALOGUE 25-1300 MHz Will this be any good for shopwatch that’s now digital?
More than likely unless its something like Tetra but i very much doubt it.
- Call Sign: mm12
Ah thanks mate I had an SDR unfortunately I didn’t get around to sorting it before laptop went south! Is an SDR worth it now? I will be replacing laptop it. I was the setup for the SDR that was the issue for me….. but given time I could set up
SDR sticks are sill worth it. Cheaper than a scanner too.
Can you recommend a laptop you can fit in an inside pocket?
There is nothing on a database for 455.750 in Warrington or a 10 mile radius at least and when I'm there nothing shows up. 456.400 is the Ravenhead retail park security in Widnes. 455.6125 is down as a factory, a shopwatch in Runcorn (never heard it) or a factory. It's also a taxi company in Blackpool with a repeater on Winter Hill so covers a massive area. 455.775 is Amazon. 456.975 could be a number of things. 453.9875 is a common frequncy it could be Halton Hospital if you are hearing it on DMR or Wigan shops and pubs if on NFM.
440.225 could be Chester Zoo, a Heinz factory or something associated with Manchester airport
I can confirm some of the above and the rest through radioreferenceuk
