SWR meter for vhf 70cm
Ur5by9
Post by Ur5by9 »
I dont have any swr meters that cover the higher vhf frequencies
however i do have many that cover the lower hf up to 150 mhz varieties
Can it be easy enough to take an SWR meter and convert it to work on the higher frequencies for the 70cm bands ?
What could be involved in simple terms.
Thanks again :wave:
Re: SWR meter for vhf 70cm
Post by ch25 »
Simple terms: NanoVNA. You can't get decent UHF SWR in that price range.
Ur5by9
Post by Ur5by9 »
@ch25 Wild prices for those on Aliexpress and ebay from £35 to £135 anything to look out for with these items ?
Post by ch25 »
If you have good eyes: https://aliexpress.com/item/4000559497296.html
but I would get this anyway: https://aliexpress.com/item/4000402236126.html
Cheaper than good UHF swr meter.
Ur5by9
Post by Ur5by9 »
Alan Pilot
Post by Alan Pilot »
The second link you put is the same as mine.
Is there a better firmware to be had at all.
